Files not getting sent to Laser anymore
Hello,
I have a Boss HP 3655 I am directly hooked up to my windows laptop via USB cable. Lightburn 1.2.04
I have been engraving files all day then I changed the origin from center to top left because I had been engraving ornaments and need to move on to other things. Sent a file to laser, nothing. And now nothing seems to get sent to laser. I have set origin back to center, reset Laser. Reset, Computer and Lightburn. (Multiple times) Turned everything off and restarted everything still nothing sent to laser. I have tried multiple files, files I used today, last week and still nothing goes to laser. I can preview files and they play just fine. I can access previous files from memory on laser, and they work. When I send a file, the file downloads and the laser beeps as if it was successful. But nothing comes on the display screen. I check memory and it is listed as “unknown”. I was successful deleting the unknown files and sent a current file from computer and it downloaded but only one time was I successful in doing this. I have tried just sending a simple square directly to laser it says, “The File Data Error !”
Any ideas what I did would be greatly appreciated.
Thank you so much in advance
Could your controller storage be full? Try removing some old unnecessary files and see if that frees things up.
Alternatively, try transferring files via USB flash drive (UDisk). Does that work?
To confirm, are you using the Send button? What happens if you use Start button?
Thank you for the quick response.
I did remove about a dozen file from memory because that crossed my mind also, I will delete more just in case. I am using the Send Button. When I use the Start button that is when I get the “File Data Error” message on laser I will try USB tomorrow as I have quit out of frustration today.
Thanks for you ideas!!!
Definitely think coming at it with a clean head will be useful. Don’t want to be creating more issues for yourself.
Let us know how it goes.
berainlb,
You were correct I deleted all unneeded files, and I am back up and working.
Thank you so much for your input
Mike
