Fill and line stay in line mode
I just got a new computer and downloaded LB for it. When picking FILL it stays in line mode. What can I do to fix this?
It is likely the way you have set your desktop view, you can change it to “filled” in “view style” under window.
LightBurn by default works in Wire Frame mode so that you can see items behind others, etc. You can see things filled in Preview mode, or you can change to Filled mode in the design workspace via the Window Menu, or using the shortcut keys of Alt-Shift-W to toggle filled rendering off and on.
