Is there a feature under consideration to add Fill Effects for vectors?
I have included an example below, done in Microsoft Publisher.
It would be spiff if this were available for objects created in Lightburn such as text, traced shapes, drawn shapes, etc.
I understand that I can draw things in Publisher this way and then do a copy/paste into Lightburn as a raster, but this is somewhat limiting and less precise.
Many of these could be drawn relatively quickly and easily in LightBurn with the native tools. A combination of the line, rectangle and array tools would get you these fairly readily.
Not to say a customizable fill tool might not make this easier. Just that you’re not relegated to trying to do a clumsy raster solution.
You should check the Feature Suggestions site to see if this has already been suggested.
