Hello!
I am having an issue with the power output for “Fill+line mode” when using recent Lightburn version compared to 1.0.06 with the same file and settings
When I send job to a controller it outputs higher wattage on a “line” engraving after completing regular “fill” engraving.
I have a digital power meter, It does not read lower power very well, so under normal “fill+line” engraving displays 0.0 ma. That is the case in v1.0.06
However when I run same file with the same settings in 1.1.00, the “Line” part of “Fill+line” outputs higher wattage — consistent 0.4 ma.
Resulting higher power is causing more residue and burn marks at the corners of shapes. See black marks on reverse side
For the time being I reverted back to v1.0.06
here is project file:
dragon5-test.lbrn2 (13.9 KB)
Setup info
Lightburn: v1.1.00
OS: Windows 10
Controller: Ruida RDC6445G(EC)
Tube: Reci T4 (rated 117w on a sticker)
Power supply: NMG 100W
Connection: Laptop to Wi-fi router, router to controller via wired LAN
