Fill+Line Issues
I’m not sure what is going on with the Fill+Line issues I am seeing. At first I thought maybe I’m loosing steps but I burned a tiny spot at 0,0 and then when done returned to 0,0 and was right on. As you can see Overcut and Kerf Offset are both set to 0.
Some things I do with Fill+Line I don’t see this issue with the same settings, looks the same as if I did fill only.
Below are images of what I’m seeing, clearly the line pass is outside of the original vectors. If I was loosing steps the outline would be all to left/right or top/bottom but they are not.
What am I missing here? The more I look at these images wondering is the fill not completely “filling” do to my settings?
Any help would be great, this is a DIY build using GRBL.
Thanks!
Fill only:
Fill+Outline:
Settings:
And same thing happing with just text:
