I typed in a word and used the offset function to surround the word for a cutout. When the program is run, the word (fill function) is offset 1.25" to the left of the line cut. If offset fill is used, the word is centered in the line cut as it should be. When I run preview, it looks the same when fill and offset file are selected; the word is centered in both cases. I tried turning off the machine and restarting from scratch but always get the same result. How do I solve this problem?
Can you show us a screenshot of your issue?
Layer settings could be useful too.
Here is the screen shot along with an actual test.
We are on the latest version of Lightburn.
As noted before the “offset text fill” or simple “line text” is center within the second layer frame, however, when FILL mode is selected and no other changes are made, the text offsets itself out of the frame about 1.25". This seems to be a software issue as we don’t see a setting that would fix it. I did change the “Align X” under fonts to the left and it shifted text but still was not centered exactly. Preview in all cases looks like everything is OK. What can we do to fix this?
TextFill test.txt (21 Bytes)
Check this:
