Fill mode representation v1.6.03 W11 not "shaded" as in other install
Hi, I did search and couldn’t find or not using the correct terms.
I installed LB on my Surface Pro9 just recently and just started using it and noticed that when you assign “fill mode” to a layer, draw a primitive shape it is represented as if it were in “line” mode. In my other install the fill mode has the layer color shaded inside the perimeter of the shape.I looked in all the places and don’t see a way to toggle this. Any pointers would be appreciated.
Summary
This text will be hidden
Window> fill/coarse
or fill/smooth
I did NOT look in that selection. I did “reset defaults” there and that didn’t work. I have my shading back…Thank you for your time and help!
To eliminate other differences:
Thank you very much. I started down this path but I’m ~2000 miles from the original PC and the remote function is down. I have cloud access to my files and everything came in “wrong” so I knew it was some setting on the new install. I should have checked everything before I got on the road… Guess what I’m going to do when I get back LOL.
edit; I also thought I had those settings in the cloud but…
I hate the feeling just after that. :slightly_frowning_face:
