Fill setting adding outlines
Hi Everyone,
Have you seen this behavior or maybe have advice?
This all worked fine, until a couple of days ago when I had a computer blue screen crash. Now my fill settings produce a pre outline in some parts of my design, or text used. The files have not been modified, just using the same saved design I used many times over with no issues.
This is a multi layer, with fill as first, then outline as second layer. Now since the crash, it outlines the object, then fills, then does the actual outline layer.
Strangest is this is one text line, and not two separate objects, and happens on any multi-layer setting.
I cannot get it figured out, and checked all the settings I can think of.
Thank you
I believe and will contact support that this is a problem in the latest release of Lightburn. With the computer crash, I thought it was linked to it, but the day before the crash I upgraded to LightBurn-v1.2.03, but don’t feel the crash is linked to the new version.
The crash was just a overloaded system I feel with me trying so many different things to figure out why the settings, and operation in Lightburn was not working for me.
I downgraded to LightBurn-v1.2.01, and all my Lightburn functions are as before.
Thanks Peter
I’m not really up on the multi mode with layers, but it looks like you have a fill and an outline on that layer…?
The ordering being incorrect for some multi-layers has been found and fixed for the 1.2.04 release.
thank you Team Lightburn.
Tested in new version and can confirm the problem I had was fixed
