When using the NEJE A40640 laser during a fill / line application the center of the fill area is lighter than the exterior areas.
I assume it is because the laser is on off on near the edges so it would be darker there possible due to the laser starting back up after changing directions.
Is there a setting in Lightburn that could help to cause the fill to be more consistent ?
I am using the fill command on 3mm poplar plywood
Thanks
Tom
