I’ve had my fiber laser and used it quite a bit with lightburn for the past year or so, so I’m pretty familiar with it, but I’m not sure what my issue is here. When I try to run this file in fill mode on a Pmag
I’ve tried everything I can think to try. I’ve ungrouped the file and selected a small section that I can see is definitely a closed shape, put it on its own layer set to fill, and it produces the same outline result.
I just checked, it’s not duplicated. Not sure why it was showing blue there, I just turned the laser back on and it shows the black layer now, same result though.
What I’m trying to accomplish, and what the preview shows should be accomplished, is for the shapes in the design to be filled in. What its actually doing, is just tracing a line around the perimeter of the shapes.
Your file runs fine here. I just changed the SPD/Pwr to burn on scrap. It also runs fine with your settings. It just doesn’t burn enough for a picture.
I’m Still not sure what the issue is/was, but I loaded this file on a different computer, and it ran as expected. I tried restarting the original PC, no joy. I’m thinking I’ll uninstall/reinstall lightburn on that pc.
