I drew a square in Lightburn. When I select the palate at the bottom (any color) it only colors the line. How do I make it fill in the square with the color I selected?
Can you upload the file?
Use the preview or go to device settings
and change the display to filled rendering…
Use the preview
, it will save you lots of time and materials.
You can also change how it’s displayed on the workspace…
Good call Jack.
Also under the window pull down menu.
Ok filled rendering fixed it. Thanks!
I use filled rendering a lot, but with lots of items, it may make them difficult to deal with… If you have multiple items, it may ‘hide’ them from you… I’ve switched the layer from fill to line, so I can select them… You’ll have to figure out what works best for you…
The preview is really your friend…
If this fixed it, please mark the correct thread as solved…
Take care, good luck
How do I mark this as completed/fixed? Thanks everyone
