Ideally would like to be able to have a fillet option. Simplest would be for 90deg corners such as on a rectangle. So we’d select the rectangle, then define a radius…
Is there a boolean workaround.
If you just want it for rectangles, you can use the Corner Radius property on rectangles in the Shape Properties window.
A fillet feature is being worked on, but not ready yet.
Thanks Oz. I gotta keep that optional properties box up. I also figured it out with booleans as well. Appreciate the fast response!
Started with this…
After Boolean Weld
Added Second rectangle
After Boolean Subtract
