Filling outside the lines
I have a new install of lightburn and a ruida controller.
When I set to fill, it burns either side of the image on the x axis.
Line 1: line
Line 2: fill
Line 3: fill+line
Line 4: offset fill
Any ideas why?
Hard to tell from the photo but you may be dealing with this:
Configuring a Ruida - LightBurn Software Documentation
Thank you, that fixed my inverted x controls, but not the double imaging.
It looks like its doing a fill either side of where its supposed to be.
Did you look at the ā€œFix Skewed Engravingā€ portion?
Thatā€™s what Iā€™m thinking it might be.
But Iā€™m reconsidering based on your description. This might be an issue of offset scanning. Try running a fill of a rectangle with line interval at 1 mm. Whatā€™s the behavior?
I see the issue, but how to fix it?
It looks like backlash, check for something loose on the X axis
Ooh,
I had a similar problem where tool head wasnt coming back to the correct x position when i used cough engravelab.
I had to turn off the machine when changing the settings from rotary to table and back, a lengthy, drawn out, painful procedure.
Thank you for the help.
The issue is now resolved
Speed from 50mm/s to 1000mm/s, increments of 50
The table
The final result
The numbers you have for backlash look extremely large to meā€¦ Here are a few of mineā€¦
Screenshot from 2022-06-01 08-15-15
I think you have other configuration or hardware issues. It shouldnā€™t backlash 3mm.?
Maybe someone else can chip in on thisā€¦
Wouldnt surprise me at all. This machine has been a problem from day one.
Within the first 12 months:
Replaced x axis motor
Replaced x axis driver
Replaced table/rotary switch
Found bad solder joint in rotary
The feed through is in the wrong position and unuseable
No documentation available for engravelab 10
All Iā€™ve been wanting to do is engrave pictures on glass.
The stupid thing is I used lightburn on the emblaser2 and never thought to try it on the co2.
Ill see if i can find anything like backlash settings in engravelab.
Ok, here are the ā€˜factoryā€™ settings. They were set by the guy who installed the laser.
Looks like Im not to far out, but now Im concerened they need to be that big.
Backlash in itā€™s simplest terms comes from the clearance required for the parts to operate. I canā€™t imagine it taking a mm of clearance for it to work.
These belts are basically cam shaft belts and have very no ā€˜slackā€™, itā€™s hard to stretch or compress them. The drawback is they are really designed for a single direction, not back and forthā€¦ I wouldnā€™t think that would make for such large values.
Good luck
I had a word to the manufacturer, they told me its because they use servo motors, not stepper.
Great, my work with servos was decades ago. Sounds good since I donā€™t know any betterā€¦
