Hello, I’m still learning on LightBurn, and this may be something that is specific to my laser. I have the aufero laser 1 with the ortur LU2-4-SF. It seems to engrave well, but I’m still getting some lines in the engravings. Maybe this is normal, but I see other that look very clear without the lines. I will attach the file I’ve used and attach photos that you can see the lines. Or maybe I’m just being too picky… I don’t know Ive tried the different fill settings as in fill and line/ offset fill, but it didn’t give what i was looking for…
fly coaster.lbrn2 (183.1 KB)
A few things I would recommend you try:
- Try running the Tools->Interval Test to see if you find the optimal interval for your laser. It seems you may be getting some artifacts from your current interval setting
- Experiment with different scan angles and cross-hatch. This will give you a different look that you might like.
- Try defocusing at different increments above the focus distance. This will give you a slightly duller cutting beam that smooth out the burn. Again, this will be an aesthetic choice.
