I am having a problem where at the end of the project the laser does a final outline. The issue is it does it at a very high rate of speed no matter what i have the project speed to. This results in the laser bouncing around and more often then not at some point the outline ends up out of alignment. I have tried to search for an answer and have been unable to find one.
If you have problems like this, it’s best to post it in the Ortur area as most people knowledgeable of the Ortur keep a finger on the pulse there…
You should probably post the offending .lbrn2 file for us to examine and ensure it’s not a problem there… you can drag and drop the file on the reply window and it will upload it…
It’s nice to be able to duplicate the issue to see what’s happening.
