I have three NEMA17 stepper motors that are labeled as D42HSC1413B-24 Lot # 190708…the rest of it is in Chinese. I am using them with Arduino plus CNC Shield V3 w/ StepStick drivers to drive a laser diode engraver. They are sized 42 x 42 x 34. I cannot find any datasheets in order to adjust the drivers v/ref. Any assistance would be appreciated. Thanks in advance.
The NEMA motor is in inches. A NEMA 17 is 1.7 inches on a side…
This is a pdf, remove the .txt extension when you get it downloaded…
Data-Sheet-Stepper-Motor-Support.pdf.txt (839.0 KB)
Hope this helps…
Good luck
