VeeraM
(VeeraM)
February 19, 2024, 7:17pm
1
For my hobby, I purchased a Falcon 10W laser, but I’m not satisfied with the accuracy of the laser beam. Is it possible to adjust its precision? None of the circular lines are aligning correctly.
ednisley
(Ed Nisley)
February 19, 2024, 7:40pm
2
Yes indeed!
A recent discussion shows what’s involved:
Hello:
I have a non-linear scale problem when patterning an alignment grid on a waste board.
I am using the newest Light Burn version V1.5.01 with an extended version (400 mm x 800 mm) Ortur Laser Master Pro 2.
On my first grid pattern attempt, I made a 1 in grid pattern in Light Burn. The line width was narrow measuring a 7 mil in line on test burns. I offset the line on both sides, removed the reference line, and filled the offset line to make a 20 mil in line. I set the direction of the fi…
Your hardware will be slightly different, but the general idea is to inspect everything to make sure it’s properly adjusted.
