I wonder if there is any possibility to finish an aborted Job after, for example, lost connection - I know about the possibility to start the Job again with a Scan-Angle 180°, but if the connection is lost again, the work is lost!
So it would be great, if it could be possible to start the engraving at the last position - is there any possibility to to that?
Now I don’t know for sure that this will work as I haven’t tried it, but, and with many assumptions about many things,
You can try restarting using the preview facility “start from” and see if you get lucky.
