Fire button not working in V2
Every time I download V2. software my “fire” button stops working. I am using a Foxalien Masuter Pro and have no issues running previous versions, I have checked my settings and they are turned on and I’ve increased the power but nothing works.
If anyone has a suggestion it would be greatly appreciated!
Thanks in advance, Bill
I just did this for another user. Maybe it will help you figure out what is happening…
I just tested the Fire button with v2.0.04 (Win10, diode laser) to see if I could duplicate your issue.
  1. Fire on/off works as expected.
  2. Laser On When Framing enabled. Laser behaves as expected.
  3. Fire button on, laser on. Frame, laser frames with laser on. Frame ends, laser remains on. Fire button off, laser off.
  4. Laser On When Framing disabled. Frame, no laser as expected.
  5. Fire button on, Frame, laser turns off as it should. Frame ends, laser stays off as it should. Fire button still red. Click Fire button, goes grey, laser still off.
  6. Fire button (red), laser on. Fire button off, laser off.
Summary: I see nothing that duplicates your complaint about the Fire button.
If you still have this issue, describe the detailed sequence of events leading up to and during your test. Without the exact details, there is no way this can be resolved by the programmers.
