Fire button quit working
My Falcon A1 10w laser has been working fine using Lightburn, until today. When I setup to center a project I hit the Fire button, and the laser did not respond. This feature has been working normally but for a new setup it quit. The laser works correctly framing, and operates normally in all other areas. I tried the $30=1000 command in the console and am at odds as to what to do next. Any ideas?
Make sure it did not get
turned off, or %=0, somehow.
Thanks for the response. Nope, I tried that this morning and that was not it. My settings are;
$30=1,000
$31=0.000
$32=1
Those settings are good, but do not affect the fire button opreation.
Can you give us a screen capture (WinKey+CTRL+S) of the Device Settings, Basic Settings window?
These $ variable values are actually set on the controller, Lightburn also has to have the identical 1,000 value in the S-Value max setting.
Don’t know if this will fix the issue, but it can be an issue. Normally this stuff doesn’t change unless the operator does it..
:grinning_cat:
It is strange that framing works and fire doesn’t since I believe they both work off the same % value set, and the fire button will not be available if disabled.
I have learned when things suddenly start acting up that loading a different preference from backup before the problem can fix problems.
