Fire button stopped working after update to newest version
I recenlty updated to 2.0.05 and now the fire button does not work. It was working just before the update.
Did you check these buttons?
Yes, and I restarted the program after to make sure.
Reinstall the previously working verson and confirm the Fire button works. Then export a Bundle and save. Reinstall v2.0.05 and import the saved Bundle. Let us know if the Fire button now works.
Be aware the Fire button only works on Diode lasers.
I had this with my diode laser…it turned out that my S Value-Max wasn’t in sync with my $30 setting. Maybe your problem as well?
Thank you for your advise. I did go back to the older verison and found that it was not working then either. Did a little digging and reinstalled the lazer and tried a different GRBL. That made it work in the old version so I updated and it is working now as well.
Glad you found the solution. I would hate technology but I earned a fair living because of it. :grimacing:
