Hi im not sure if this can be done
But i want to turn the fire button on (low so it doesnt leave a burn mark)
When i do a frame so i can make sure the artwork fits in the item to be engraved
Thank
Your profile doesn’t list a laser type. Assuming you are on a diode laser running a g-code controller:
- Enable Fire Button in Device Settings
- In Move Window set Fire button power settings to appropriate level
- Frame will now fire when in use
This assumes latest version 1.10.00. If on previous versions hold shift while clicking Frame button.
Hi thanks for that works a treat ![]()
Mark
