Hello, I’m trying to follow the first project in the lightburn tutorial but for some reason I’m getting lines outside of the shape i want. Here’s the image of the path I’m getting with the preview.
The red lines are traversal moves. They do not represent the burn area. The traversal moves go beyond the area of the engraving because you likely have overscan set. This is represented as a percentage value in your cut settings. It’s distance as a percentage of speed. It’s meant to reduce burning at the edges of the engraving. It can also turn be turned off.
