Hi, I’m a first time user for Co2 lasering.
I connected my Vevor 50W laser with rubia to mij windows 7 laptop. the connection
works fine, however the output in the machine is upside down and mirrored.
Can’t find the issue in LightBurn or the machine.
Who can help me?
well, that seems to be right. However if I set the laser position in Lightburn more to the top, the laser itself goes down, and position down it goes up. Than if I set the tekst in mirror it is upside down but proper readable
Does your definition here
matches your laser origin?
When the machine boots or resets which corner does it move to?
This is the corner that’s selected in Device Settings → Origin
I don’t think multi origin should be enabled.
when resets its goes to thee left top corner, where is expect it would be the left bottom corner. after that it going 5 cm to the right and about 10cm from top. Then it stops.
Disabeld the multi origin and the result is still the same.
The origin in the device settings needs to be upper/left.
Multi origin is not something many use, better to have it disabled until you need it.
Yess, that did the trick.
Thanx. So simple afther all
