I only have 200 more flasks to make before December 20. I cut the boxes out of cardstock six layers at a time using print and cut. These are examples of what I am making.
The ape flask is popular, both as the shown flask and with “Not” before “My Ancestor”. I have 30 different images I use, including dragons, flying pigs and a really weird armadillo. I charge $10 extra to personalize the back of the flask with a name or message. I use a Neje Max4 E80 for the boxes and a Thunder Laser and Brilliance marking spray for the flasks.
thanks for sharing this @Geriatric I’ve had some experience with marking sprays and its nice to see this working for you across the beveled part of the flask as obviously your focal point will shift as the lens passes over the different levels of the surface!
What focal length lens did you use on the Thunder laser?
I used a 2". Unless I’m doing some deep cutting or fine detail work, that’s what I stick with. For these, I defocus by 2mm.
