Not sure if this has been brought up, I searched and found other issues with flipped images, etc., but not this one in particular.
Maybe I’m not thinking about flipping the same way as others.
To me flipping vertical seems that it should basically be the same thing as rotating 180 degrees but when I flip a group of object, it also flips horizontally.
Looking at it that way still shouldn’t flip the object horizontally as well should it?
I’m vertical flipping half of these door frames to save a little space. Notice that there is slot for a hinge so the door opens from right to left, after flipping vertically it now opens from left to right -
Before
Has to be the coffee.
If you rotate, yes the hinge slot will change sides.
If you flip, it is looking at it from the back so no change in the hinge side unless you flip both horizontal and vertical.
“Mirror vertical around objects Y0 axis” is what the icon shows … But it actually mirrors along center of objects Y axis… AHHHHHH Mirror vertical along objects Y0 axis and move object half of the objects Y vertically… lol
If I didn’t already cut the doors… There’s etching on the front and one side is pre-stained so can’t just flip them.
But I can fit more doors than frames on a board, so I guess I’ll cut new doors for half of them, just need to remember to “flip horizontal” the text on the doors LOL.
