Focal length or distance from the material I should set for the latitool 50 laser?
@richmcc could you please tell me the focal length or distance from the material I should set for the latitool 50 laser?
Hello Friend,
The information that you’re looking for is very different from the subject posted here. I’m moving your post to a new thread. It really should be its own post.
The @ reply that you made will still inform richmcc that you’re hoping for a direct response.
I don’t have the Latitool or the IWECOLOR laser. Are they similar?
Posting the Firmware information from your laser engraver can be quite helpful. It may allow us to see if something matches identically and came from a similar supplier.
With the productive cover on the laser the cover should be 2mm from the surface you are engraving
