Focus test lines no numbers
Hi. I’ve recently swapped computers and I’ve been using the milling side of my machine for a while. So i have initiated a focus test on setup and I’m only getting the lines which are about 10 to 15 mm long no numbers like before. What am I doing wrong in my set up please??
What version of LightBurn are you using?
Can you click on the preview button in the focus test and see if that includes the numbers?
Can you also provide a screenshot of your focus test dialog so I can see what values you are using?
I don’t know what happened but but i selected all the z controls in settings instead of just the z stop and it worked fine after that. I’m now having issues with the Y Axis which where occurring at the same time as the 1st issue.
Not sure what you mean. Can you explain further or provide a picture?
