Focus test Z travel to 100mm
Good afternoon (o;
Completed my retrofit of an Anycubic Mega X printer to a small LED laser engraver:
But as the Z-height is over 200mm for this machine I see that the focus test parameters are limited to 100mm maximum…
Is there a way to add a Z-offset to the focus test?
Even in layer settings I can’t set Z-offset lower than -100mm…
I tried with:
$H
G0 Z-100
G92 Z0
Which works on the first run…the second time it wants to set Z Zero at Z-200.
thanks in advance
richard
Ah it seems Grbl needs a G92.1 at first…:
G92.1
$HZ
$HX
$HY
G0 Z-100
G92 Z0
