Hey everyone,
I am wondering if there is a way to focus a lightburn camera. I own a boss hp2436 and mounted a LB 8mp w-95 about 18 mths ago and while it has alway worked well enough I find that the picture is exteamly blury for an 8mp camera. Latley I have been trying to do so more detailed / smaller projects and it’s not accurate enough to get the job done. I clean my lens when I clean my laser lens as the smoke will for sure fog up the camera lens, so I know that’s not the issue. And it works fine when precise placement isn’t necesary ie when you’re vectoring onto a piece of wood and making a cut after leaving scrap. But if I want to say, add a name to a spoon handle the captured image is so blury that added your name and then you decided you wanted a box around it the box would likely be off centered. The camera is of course aligned and I have adjusted the lighting every which way along with the brightness and exposure but it’s still very blury. You would think an 8mp camera would take a better picture kind of blury, and it always has been, but in order to utilize it for more laser quality work if isn’t working as you would think. Which is why I am asking if it can be focused asthta would likely solve the issue, Thanks in advance.
There is a very small focusing notch on the camera that you should be able to turn. It may be glued tight but a little persuasion should allow you to turn the lens to allow focusing.
