I am getting this message and as someone suggested the autojoin option is grayed out. I am also uploading the file.
amelyissue.lbrn2 (352.1 KB)
The problem comes from the letter T in your design.
I found that by selecting CONTINUE from the warning page, and then comparing the workspace vs the preview. I saw the three T’s were removed.
Solution:
Select the entire text block
Convert to PATH - note, you will not be able to use the TEXT tools once you convert to PATH
Select entire text block
Use Boolean tools to WELD the overlapping shapes
Now there are no more open shapes.
Side note: Be careful of posting phone numbers on the 'net
Thank you, I will try tomorrow and see how it works.
