Trying to use a single line font and getting the disappearing text issue (especially if text includes “A”, “J”, or “R”). Turning off welding as suggested by Oz at Simplex or line-type font works, but the problem is that it turns itself on by default when you select the Text tool. You can deselect the Welded slider, but as soon as you click in the drawing area to start typing, it reenables. The only workflow that I can think of to get around it is to type with welding enabled (if you can see what you’re typing), then switch to select tool, select text, deselect welding, and if you’re not done typing, select the text, position the cursor, and keep typing. I believe I’ve even seen it spontaneously reenable while I’m typing.
Is there a setting I’ve missed somewhere to make LB content to leave welding off, a bug, or both?
Also, how is SHX font support coming along? Almost anytime I import external graphics rather than draw in Lightburn, it’s from CAD, so SHX support would be a good deal for me.
Thanks!
