Font will only output in 'line' mode
LB was running fine without issues. I started making a file on my macbook pro consisting of several labels to be burned on the ORTUR. The font displays in ‘fill’ mode on my mac, but when I open the file on my windows-based tablet, it only shows in line mode. In the preview window, the font is filled in.
If I toggle between line mode and fill mode the display is the same. But when I go into ‘preview’ you can see the change is happening.
If I leave it in fill and send to the laser, it only burns in line mode. Any ideas??
LightBurn provides the ability to show fills on the workspace. You may not have both computers set the same.
Thank you Rick! Finally had the opportunity to try this tonight and it worked.
