Fonts and best to use for laser cutting
What font(s) do you fit well with a laser for those of you who have a projector? All fonts (braille font translator) used by the stencil are not very attractive or qualified. I’ve been looking for some time and typically modifies the SW pattern, but it isn’t very successful. To wonder what other people are doing.
I’ve come up with the same problem. I have found through my work that the issue is linked to the existence of true font type. Each character obviously needs to be made up of a closed loop. This closed loop ravages lasers and gravure. It is this circle. One manufacturer for whom I work uses DesignCAD to turn a true form font into a stroke. This DXF will feed and generate the component directly with its CAM tech.
I’ve been playing with a prototype of DesignCAD. In order to solve this problem, I am close to buying a copy. Of example, however, the documentation kit adds another degree of difficulty.
