You have âsainsmart 3018 Proâ listed as your machine. I am not familiar with this system, the type of laser nor the controller/firmware used to drive it. Please provide this information.
In general, it looks like the laser is not firing as it slows down for a direction change, indicating you have the âMin Powerâ set below the fire point of your laser. What settings do you have for this layer?
Thanks Its the GRBL software using the woodpecker 3.2 control driver board, as a Note lightburn was running correctly at one time I donât know what I changed or how I changed it but in the Picture is what I am getting now
My Trial runs out in about two days, Laser Engraving a Picture is Working Fine, I must have changed something ?
Please post a screenshot (not cellphone pic) of the settings for this layer along with your Device and grbl settings.
It is now cutting the full letter But now the Laser is not cutting Off when moving to the Next Letter
Andrew Manus
You still have not told us what version of grbl you are using and its settings. We canât help you if you donât share this info.
This is most likely a grbl/LightBurn setting mismatch, but until we can see those settings it is just a guess.
For grbl 1.1f and later, check your setting for $30 and $32 in the console by typing $$ and pressing enter.
$32 should be 1 (enable laser mode)
$30 should be 1000
The $30 value can be set either in your firmware to match LightBurn, or in the LightBurn device settings (S Max) to match your GRBL setting.
This is what I found out I can put Text or a Shape in the Drawing area Then Save it under G code then
bring the Code up in Note pad then Change the M4 to M3 and save the program. And my Laser burns the Program Great So How do I get Lightburn to Change M4 to M3
Thanks Andrew
@amanus, we still donât know what firmware and firmware version you are using. Is there a reason you are not sharing this information?
GRBL Version 1.1f.20170801:OPT:V,15,128. Sorry I just assumed you had the same problem from other users
Andrew Manus
If you want to use M3, you can do so by clicking âDevicesâ, then creating a new device using GRBL-M3 instead of just âGRBLâ. Delete the old device so none of the old settings pollute the new device.
When Rick asks questions about what device you have and what your settings are, itâs because LightBurn supports so many different lasers that in order to give correct advice, we have to know what your device is and what the settings are. Without knowing that, thereâs no way for us to know if other users have had the same issue.
And Rick did give you the correct solution for your issue, if you want to continue using the M4 device, here:
If youâd prefer to switch to using M3, follow the steps I wrote above.
There are No choices Listed Under New Devices, Should I Reinstall lightburn
I chose the GRBL m3 an it worked. So As Guess I went back to GRBL 1.1f and Now everything is working properly All lines and Shapes are closed the laser will fire I can set the Variable Power. I really like the Lightburn software and will Purchase it. Thank you Rick an Oz, Sorry I was so Vague.
Andrew Manus
Glad you are all sorted.
