Create rectangle
Select rectangle
Unlock aspect
manually change dimensions
If you now click Convert to path it will revert to old dimensions.
Thanks Bret, but I just tried the steps you define and do not see the same issue. My result is the rectangle retains the new dimensions. Please provide additional information to help us reproduce. You have not told us the OS or LightBurn version you are using, so that would be helpful to share as well.
Version 0.9.02 Windows
You can see it happen here:
If you unselect it before convert to path its fine
if you resize after convert to path its fine
I just tried in updated .04 and this issue was fixed.
