How to add glass to material library
I found this. I hope it helps:
“This is entirely user-generated - You set up a cut layer however you like and save it to a Library.”
https://lightburnsoftware.github.io/NewDocs/MaterialLibrary.html
Thanks will Give a Try
It’s pretty simple… However I have mulitple lenses and I’ve found what works well for a 1.5" doesn’t work well for a 4".
My material libraries are now ‘headed’ with lens type.
4 inch lens
plywood
cut
cut/kerf
light engrave
Acrylic
cut
cut/kerf
light engrave
2 inch lens
plywood
cut
cut/kerf
light engrave
Acrylic
cut
cut/kerf
light engrave
and it goes on for the other two lenses…
Good luck
