winnerj
(John)
January 16, 2021, 5:48pm
1
Purchased FoxAlien LE-4040, connected to Windows 10.
Trying to get setup but not sure which GRBL to use, is there a specific driver or firmware setup available that I need to run to get this to work?
Bonjour
(Bo)
January 17, 2021, 3:16am
2
What firmware is your machine running?
winnerj
(John)
January 17, 2021, 4:27am
3
I am not sure, would you point me where to look for that information.
winnerj
(John)
January 18, 2021, 3:53pm
4
The firmware is GRBL 1.1H
Would there possibly be a working profile for this machine that would work on Windows 10 someone would be willing to share?
Bonjour
(Bo)
January 21, 2021, 9:47am
5
You have read the grbl configuration documentation, yes?
[Return to main page](README.md)
# Common Grbl setups
If you have a GCode-based system, like a Shapeoko, Eleksmaker, X-Carve, or Acro system, you might need to make some simple changes to get the most from LightBurn.
#### Short version:
- You might need to adjust your spindle max RPM value ($30) to match the LightBurn default (1000) or vice versa. The value in LightBurn is called "S-Value Max", in the [Device Settings](DeviceSettings.md#s-value-max).
- You might need to enable "Laser Mode" if you have GRBL 1.1f or later (\$32=1).
- If your machine uses negative workspace coordinates you'll need to apply a workspace offset (G10 L2 P1 xx yy).
- Set your machine status reporting to be relative to the workspace origin, not the machine origin (\$10=0).
#### Grbl Flavors
Grbl firmware was originally designed for CNC machines and 3D printers, with laser support added more recently. It is highly configurable, and this is both a blessing and a curse. The "standard" way a CNC machine is configured is somewhat different than the way laser machines often are. Luckily this is easy to change, and easy to switch from one to the other.
This file has been truncated. show original
