Hi all. I am a newbie to the CNC world. I have a Foxalien Masuter 3S combo and the Z control has reached its upper limit and stopped. Everything else seems to work as per "move " controls. The limit light is on and I can’t find where to turn it off. Can anyone help with this problem?
You have reached a Hard Limit, meaning it is sitting on the limit switch.
With the machine off, manually move the Zaxis down and off the limit switch. Then power it up and Home as you normally do.
Thanks MikeyH that info corrected the problem. What is a safe number for the hard limit switchs?
