Frame and G0 Y Different
Ran a 50mm test square and it is way out. Will recalibrate
Thanks for all your help. I had this some time ago with the rotary still on however I have my 78th birthday next week so will use that as an excuse.
Started to cut ribs for model plane so will need to check
Edit. On reflection some bits do not make sense to me. With the Y axis miles out I was able to cut a square to 550mm?/???
If you had calibrated it while rotary was enabled at some point that could make this happen.
Are things working correctly now?
Fantastic. Happy early birthday to you!
All appears to be working ok but will be exoerimenting
Thanks again
I think I should have marked “SOLVED”
Very good. Note that the Solution tag should be marked against the specific post where the answer is located. This helps others identify the solution to a similar problem.
