Hi all, the frame option was working perfectly fine after the first 3 projects, but now I can’t use it. I have restarted my macbook air, the sculpfun s9 laser and read dozens of comments on hot to resolve this, but nothing helps. I guess i’m doing something wrong. I know that the topic was discussed several times but I will appreciate some help. I feel that the problem is somehow connected to the goddamn macbook.
Can you describe in what way it’s not working?
What are you doing, what do you expect to happen, and what happens instead?
The laser is not moving, not performing the frame operation.
Do other functions work correctly? Are you able to jog the laser and otherwise run a job?
Can you take a full screenshot of LightBurn where you’re right about to push the frame button?
I tried to start the laser without the frame but it’s not working . I’ll make a screenshot.
The issue is you’re not selected to the correct serial port. Look here:
Looks like it should be “cu.usbserial-1140”.
