Want to slow/change Framing Speed. The MOVE panel is not available to me, remaining greyed out. How to accomplish this?
Do you have this type laser?
Galvo Settings - LightBurn Software Documentation
Basically, yes. It’s IPG, not Raycus, but same thing. I can edit that setting in Device Settings but it immediately reverts back to the old value as soon as I leave that field.
No save or write button?
Why do you want to do this?
To slow it down so to make it easier to verify with a human MK-I eyeball.
The framing is set on yours to 100mm/s, mine is 4000mm/s.
The idea is to make the whole shape visible to your MK-1 eyeballs/brain. There shouldn’t be a need to make it crawl like a gantry machine has to. If it’s fast enough it will produce a area that looks like there is no movement of the laser.
I don’t know how you would slow it down anymore except by the framing speed.
Good luck
I’m embarrassed to admit that it did not occur to me to make it that fast. Thank you. Accomplished.
Don’t be, I think we’ve all been in that boat…
Glad it’s functional…
I row it more frequently than most, I’ll wager. This is compounded by the fact that it actually has a outboard motor, too… ![]()
