Since the update the frame speed for my OMtech 80watt Ruida is slower then molasses, I’ve changed the speed on the move section still nothing. The other laptop that I didn’t update is fine can someone please help? Both laptops have windows 11 thanks
The traverse move information should be in Machine Settings.
You should be able to view, compare and edit the setting from there.
Probably best to write everything down for both computers to see what the difference is.
You may also want to consider double-checking the Units. CO2 lasers will generally run in mm/sec.
