Newbie here:
Laser Engraver Type : ORTUR Laser Master 2 S2-SF, 24V Laser Engraver, Laser Engraving Cutting Machine, DIY Laser Marking for WoodMetal ,Compresed Spot CNC,32-bit Motherboard LaserGRBL(LightBurn) Engraving Area 410x390mm
Windows: 10
I have uploaded my image that I previously imported and was able to engrave on a goblet glass. After I updated lightburn now when I try to engrave on the rotary I press frame and it will go from the current position to the right then back to the start position in a straight line. The Rotary does turn it will just not frame my design instead it frames a straight line. Everything seems to be connected properly.
Can you give me direction on what I am doing wrong.
Thank you in advance!
