as you can see in image i try frame on this job and machine had to be stopped becouse it went past the 2510mm x limit
hope someone can help
Hi, in ‘device settings’(spanner and screwdriver) at top of the screen, do you have the check bounds when framing selected?
You have your job origin in the bottom left, and by the looks of it, your home set to bottom left also.
Why is your job in the upper right…?
It’s also set to absolute coordinates.
How did you set your machine up as far as home corner?
