Framing Bug, Stops Randomly While Framing
Just updated from 1.1 to 1.1.03
Have a bug when framing
(Happened before as well when 1.0 first came out, was gone with 1.1) seems to cut dimensions fine
Stops while framing at odd times doesn’t return to origin
Mac running Monterrey
Hi Brett,
Is this problem on the 1390?
If you’re connecting via USB I’d try a new short cable with ferrite beads before any other troubleshooting. Which controller is in your 1390?
yes 1390, R V8 controller
I’m back on 9.24
1.0.3 is now only sending part of the code, its just stopping after a few minutes
I will try a shorter higher quality usb cable, that could be the issue
thanks
