Framing going in the wrong direction?
Using a Creality Falcon2 that has worked pretty good and now out of the blue when I go to frame something it goes to the bottom left corner and jams there. I have to reset the machine to get it working again. This is while using absolute coords.
Framing has been an issue with the Creality Falcon - there are a handful of forum threads about it:
It seems to work better directly from the controller than from LightBurn due to how Creality has implemented the firmware on the device.
The framing never gave me an issue before. It is something brand new. I could use the square frame or the circle frame on Lightburn. I should clarify however that I am not using a USB stick but rather using my laptop plugged into the computer directly.
