Framing issues with laser master ortur 3
Hello, having issues with my machine error [MSG:86:Error: Shock and Movement detected! Check TroubleShooting Section in User Manual.]
See below for machine settings
see below for console setting.
Summary
Waiting for connection…
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:211]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230417]
[SN:05592001F4C56EF73FFA4B42E740F908]
[VER:1.1f.20220325:]
[OPT:VNZHTS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:70:04:1D:FB:52:D6]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25150,8|H:1,7>
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:211.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25150,5|Ov:100,100,100|A:SFM>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25164,8|H:1,7>
ok
Starting stream
OLF:211.
OLM:GENERAL.
[MSG:‘$H’|‘$X’ to unlock]
Stream completed in 0:09
OLF:211.
OLM:GENERAL.
[MSG:3:Warning: Caution: Unlocked]
ok
$0=5.0
$1=100
$2=0
$3=1
$4=7
$5=0
$7=0
$10=2047
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=1
$17=4
$18=0
$20=1
$21=0
$22=1
$23=7
$24=600.0
$25=800.0
$26=100
$27=1.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=0
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.0
$57=1800.0
$58=395.0
$59=6000.0
$60=0
$61=1
$62=0
$63=3
$64=0
$70=31
$73=3
$74=Testing123
$75=**********
$76=OLM3_AP_52D6
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=20040.000
$111=20040.000
$112=600.000
$120=2000.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$140=600
$141=1000
$142=800
$150=16
$151=16
$152=16
$160=0.000
$161=0.000
$162=0.000
$180=20040.000
$181=14028.000
$182=600.000
$200=65.0
$201=50.0
$202=60.0
$210=100
$211=100
$212=100
$220=50.0
$221=60.0
$222=60.0
$270=115200
$271=115200
$272=115200
$300=OLM3_STA_52D6
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$306=80
$307=81
$308=21
$310=OLM3_AP_52D6
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$330=admin
$331=user
$332=255
$339=3
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$392=5.0
$393=3.0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=1.000
$610=0
$611=0
$612=1
$613=224120
$614=0
$615=api.ortur.cn
$616=0
$617=0
$622=127
ok
<Home|MPos:382.170,534.900,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25164,13|Ov:100,100,100|A:SFM>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25192,7|A:SFM>
<Home|MPos:-39.950,-39.950,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-79.970,-79.970,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-119.980,-119.980,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-159.990,-159.990,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-200.010,-200.010,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-240.020,-240.020,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-280.020,-280.020,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-320.010,-320.010,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-360.000,-360.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32766|FS:0,0|CL:0,0|PS:2,0|VA:25157,7|H:1,7>
ok
Starting stream
OLF:211.
OLM:GENERAL.
Stream completed in 0:08
OLF:211.
OLM:GENERAL.
ok
<Home|MPos:85.760,424.030,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25150,5|Ov:100,100,100|A:SFM>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25157,8|A:SFM>
ok
This is pretty much self-explanatory. Is your machine frame shifting as the laser module sweeps back and forth at Warp8?
Anchor the frame or slow it down.
The manufacturer should be able to tell you which GRBL parameter turns off reading that sensor if the above suggestions do not work.
So it goes from the starting point, and it just shift to the far end; and makes stutter noises
That is a different issue than the tilt sensor. Is that what triggers the error message?
What you describe here is a coordinate issue. Are you using Absolute Coords in the Laser window?
Yes I am using Absolute Coords and it is not properly framing project. Keeps going off centered.
Disconnected and reset and no solution
OLF:211.
OLM:GENERAL.
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:211]
[OLM:GENERAL]
[DATE:20230417]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:192.168.5.1]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25143,13|Ov:100,100,100|A:SFM|H:1,7>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25150,5|A:SFM>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25164,3|H:1,7>
ok
Starting stream
OLF:211.
OLM:GENERAL.
OLF:211.
OLM:GENERAL.
ok
<Idle|MPos:337.210,565.660,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25150,5|Ov:100,100,100|A:SFM>
ok
<Idle|MPos:337.210,565.660,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0>
ok
Starting stream
OLF:211.
OLM:GENERAL.
Stream completed in 0:16
OLF:211.
OLM:GENERAL.
ok
OLF:211.
OLM:GENERAL.
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:211]
[OLM:GENERAL]
[DATE:20230417]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:192.168.5.1]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:337.210,-850.140,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25164,8|Ov:100,100,100|A:SFM>
OLF:211.
OLM:GENERAL.
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25171,2|Ov:100,100,100|A:SFM>
<Home|MPos:-200.000,-200.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25157,2|H:1,7>
ok
Starting stream
Stream completed in 0:05
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF:211.
OLM:GENERAL.
error:9
G-code locked out during alarm or jog state.
ok
<Home|MPos:229.430,1171.840,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:25129,42|Ov:100,100,100|A:SFM>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:25018,87|A:SFM>
<Home|MPos:-39.960,-39.960,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-360.010,-360.010,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
ok
We already touched on one possibility. You are still getting this alarm.
Can you give us a screen capture (SHFT+WinKey+S) of the Cuts Editor window?
