Problem started after 1.6 upgrade, When I frame Di shoots right, down, up and then to start position, but often overshoots as it does framing at highest speed possible. Path is always the same, about 1/2 of what is sized in file. D1 frames correctly using X-Tool design software.
Laser is X-tool D1 10w with extension frame. Computer is either LG Gram (Win11) running 1.7.02 or MS Surface (Win 10) running 1.6.03
Please post a screenshot of your entire Lightburn screen with the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
