framing process
I am facing an issue with LightBurn. I use a Mac and a CO2 laser machine, and I have a LightBurn subscription. The problem is that the framing process—performed before the actual job begins—is extremely slow; This was not the case previously. I would like to speed up the framing movement.
Check the Speed setting in the Move window:
The speed is still constrained by the size of the frame: small frames will run slower than large ones due to the axis acceleration settings.
